Backup ONN 4K plus box
Does anyone know if its possible to backup a ONN 4K plus box. I don’t think it is but checking if some new technology allows that to be done. Just like you’d backup a computer..
@warhorse , this may not be exactly what you seek, but it gets you in the right direction
Or this…
It is not possible to perform a full system clone or direct data transfer from one Onn 4K Plus to another due to Android OS limitations, but you can back up specific app data and settings using workarounds.
Backup Limitations and Workarounds
  • No System Clone: There is no built-in feature to copy the entire device configuration, including all app logins and settings, to a second unit. Users must manually reinstall apps and sign into accounts on the new device.
  • Individual App Backups: Apps with native backup features, such as Kodi and TiviMate, can be backed up. For Kodi, you may need to grant full file permissions in app settings and copy the .kodi folder to an external drive. For TiviMate, backups are stored in /sdcard/Android/media/ar.tvplayer.tv, which requires a file manager like Es File Explorer to access and copy.
  • Launcher Settings: If you use a custom launcher like Projectivy, you can export its specific settings via the launcher’s menu and import them on the new device.
  • External Storage: To facilitate these transfers, you can use an OTG cable to connect a USB drive formatted to FAT32 or exFAT (depending on the specific model year), allowing you to move backup files between devices
I have streamlined so I can do it in 15 minutes. I use Google drive for all my backups, apk, and backgrounds. I sure wish there was a method to clone one box to another..
I used to record from TV mate using the firestick and the OTG cable and converting a thumb drive to FAT 32, how can I do the same using my ONN 4K streaming device.
Thank you for your response.. :+1:
