Backup Failure and No Links
I looked for this topic, but all I found was from 2022 and it was closed. Three questions:
  1. I’m using a Shield Pro and Tivimate.I added an USB flash drive to backup my TiviMate data. The shield finds the USB, it sees the folder I setup but it fails to backup. I don’t know if the issue is the flash drive, Tivimate or the service provider.
  2. If anyone is using Stremio, can you see if the TV series XXXX has any links. All the episodes are there, but no links come up. This is the first time that has happened with a movie or series.
  3. I added the Dropbox app to my Shield. Is there a way to use it for backing up my Tivimate data? Do I need a program like Xplore for that? Would I be using too much internal storage using this method? Since I have two Shields, this would be an easy way to do my backup, but not sure how to go about it. If I need a file manager, a recommendation of an easy free one would be appreciated.
4 posts were merged into an existing topic: How to Install TiviMate on Firestick/Android TV/Google TV
