Just switched over from Cinema APK to BeeTv. I’m having the same issue with the audio. Many times the audio will play normally on a show of a series, then when I go to the next show the audio creates a screeching, static noise. It also happens occasionally when I first use the APK.
I am having audio problems on both Cinema and BeeTV as well. Has anyone figured out the problem. If so, please advise as I am very frustrated trying different things to correct the problem with no results. Thanks very much for your help!
have you tried a different media player
No I haven’t. I didn’t even think about that. Cinema was working fine about 3 days ago so I switched to BeeTv. Is that what you suggest? I am currently using MX PRO Player
I just changed to player back to Cinema which wasn’t working before now works! Thank you very much! ![]()
Glad it worked ![]()
Again, thanks for your help!
