Almost constant buffering
I am new here so not quite sure if this is where I can ask for some advice. I was using a firestick but recently upgraded to a Fire Cube. It was working fine for a few weeks but about a week ago it started to buffer a lot. I tried several things to fix this but nothing works and it is almost constant . It struck me that maybe the problem was with the app since a relative has a different app and hers does not buffer. I downloaded a different app and that works fine. I still have the original app and want to correct the problem. Are there any suggestions?
Can you describe in more detail? What app are you trying to play, what have you tried? Are you using a VPN, what are your speed test results?
Download tp app and use tech doctor app to disable the default system junk on your firecube it speeds it up and stops a lot of buffering at least it did for me
What app are you using that is buffering?
