Advanced Receivers
Which APK for Movies is best suited when using a 7.2.2 home theater system or is there a particular Kodi build ?
You don’t need a specific build, you just need to setup your audio settings correctly. Watch my video. It’s covered in there. Also make sure your actual device audio settings are configured correctly. Fire sticks and most streaming devices aren’t capable of passthrough of TrueHD uncompressed audio. That’s why I have a Shield Pro.
I would say you could use any of the VOD apks that play well with Real Debrid. It isn’t necessarily about which app you use, it is about pulling the proper sources to take advantage of the high end audio. Real Debrid has the most sources with Atmos, DTS, etc. Also like Jayhawk said the settings have to be properly configurated as well. Syncler+, Stremio, the better 4k add-ons of Kodi, even Cinema and some others would be able to take advantage of this with a RD account.
