One of troys videos shows how you can install both 18.9 fork and also kodi 19.x on one device and use either.
What an amazing response from so many of you. I wish that some other things that I am involved in had the same level of professionalism as all of you have exhibited here. Again, Thanks.
I second this. I found my VPN setup was giving exactly the same condition you have experienced.
Check on your VPN providers help page as this is a common problem.
I tried loading Fen as well and got the pop up message “Couldn’t retrieve directory information” I typed the URL of the repository correctly, which leaves me to believe the repo address changed. I did a little research, but couldn’t locate an updated repo address. Every site lists https://tikipeter.github.io Fen is compatible with Kodi 19 so I guess we will have to wait for the creator to update his repo. Be assured this isn’t user error on your part.
Look at my response at the top of this thread. The URL is dead so it’s contents don’t exist any more. That github page no longer exists.
