Originally published at: 1 Pix Media on Firestick & Android TV (2025 Guide)
This review guide features 1 Pix Media with installation instructions and full details on Firestick, Fire TV, Google TV, and Android TV devices. 1 Pix Media is a live streaming app that centers around live television and sports. Users will also find options for Movies/Series, Adult Content, Documentaries, and more which makes it an AIO…
I tried it and took me a while to figure it out, and I agree the ads you can no get out of are irritating.
In the end I uninstalled it and the player as I had other options that worked better for me.
I couldn’t get the code to work. Didn’t go to the correct download page. I tried it a couple minutes ago. Will pass since it has so many ads. I usually like to tryout the new apps.
Same here. Tried it a fee times and keep getting “the webpage could not be loaded” error message
I didn’t see anything about not being able to post links in the rules, so I will post this and if it is not allowed it can be removed or I will remove it if asked.
When I had it installed I got it right from this site. and it worked well, that was a while ago and it took me some time to figure out how to navigate it, but it worked well even with the ads. I did find that having a mouse pointer was helpful. I have not watched Troy’s video or set up of it he may have covered that.
Odd that this would work for you, as the codes used are identical to the ones Troy posted.
Maybe something changed I installed it 4-6 weeks ago, probably by the time he did his post/review I had removed it. I may need to try again.
Edit to add.
I just used 790093 and 337646 for the player and it is playing fine. I have not seen an ad yet other then on the live channels.
Thanks @DaveZerf
Just downloaded both with no problems. I’m liking the channel lineup. There are couple channels that I don’t currently have, so I will keep as a backup. I have already created my favorites.
Gotta love our TP Insider Community !!!
Glad you got it working.
1 Pix is far from user friendly and setting up the favorites is a real pain, and a complete epg would be great. Too bad cause the channel line is quite good.
I’ m curious, what are the other options you use?
Totally agree, but its free. So, I deal with minor nuances for the channels that aren’t part of my IPTV sub.
I added it w/o any programmatic issues on my ONN 4k Pro, EXCEPT the app won’t appear in my Home Screen “row of apps” no matter how many I delete from the App row? What’s that about?
It’s not an android tv apk. So if you want easier access to the app try to use sideloady.
Sorry @Twin22 not sure what you mean. What do you mean it isn’t an Android APK? Keeping in mind that APK is an Android Package Kit for installing Android Apps.
forgive the terminology error. All I meant was 1 pix acts like a mobile phone or tablet app. Will not appear on the android tv Home Screen. Need a launcher if you don’t want to dig in your setting to open it.
Are you referring to an actual TV and not an Android TV device? Sorry but I am still confused as this App is definately an Android TV app as in Android TV OS and loads flawlessly as well as play streams flawlessly. Both 1Pix and wuffy icons show up on the home page although I removed wuffy from there as I don’t need it on the home page.
I’m referring to android tv. I’m using an nvidia shield. I have 1 pix installed but I have to go into settings, then apps to access it. 1 pix does not appear on my Home Screen unless I use a launcher.
Ahh but you said it wasn’t an Android TV Apk and it is, and it does install on an Android TV streaming device and during installation places an Icon/shortcut on the home screen. Not sure why it doesn’t appear on your home screen. I’d have to dig my 2019 Shield Pro out of the drawer and hook it back up to help you. Maybe someone else with a Shield Pro can install it and give you a hand.
This works great on my firestick but is a no go on my andriod tv
