Xtreme codes on Kodi
Hi y’all anyone know how to add Xtreme codes to Kodi? I think there’s something you have to install on Kodi but not sure how to do it! Any replies would be appreciated :+1:
Been using KODI for more than 6 years now. I’ve yet to see someone succesfully run their IPTV service in KODI. Yes there are several addons that have live IPTV but that’s different than running your own IPTV service in KODI. Not saying it can’t be done - just haven’t seen or heard of this
Hi! Well I have a subscription for iptv and wanted to see if Xstream codes would work on Kodi but from what I’ve seen on the web you have to install an addon in order to do that! Just wondering if anyone knows how to add it to Kodi.
The only thing I have ever even heard of is this. https://kodi.wiki/view/Add-on:PVR_IPTV_Simple_Client
I have no clue about it at all or have ever tried it. Not even sure if it is what you are looking for, but came to mind when I read your question.
I did try a service using Simple Client on Kodi. IIRC, I think that you must use a m3u file instead of an xStream URL.
MY feelings were that it was a very clunky UI, not worth the effort.
If you’re looking for a free player, IPTVSmarters is a much better experience.
(And I AM pretty much a Kodi apologist.)
Ok thanks :+1:
It can, but it’s very clunky using Simple Client.
Interestingly, Kodi can be used as an ‘external player’ if you don’t have audio for channel when using Tivimate. Kodi also works well in playing a local file (.ts) that was recorded with Tivimate.
