Anyone know the newest Xtreme code for PK?
What are Xtreme codes and how do you use them?
Xtream codes are playlist urls that are much shorter than m3u’s that have the epg embedded in them…much easier to enter into a player.
How do you determine what the Xtreme code is?
It’s sent to you from your iptv service in the email when you subscribe…it’ll usually have a port number at the end…like :25461 or :6969
You should go over our tutorials for the bst help as they do explain it and how to put them in the players, they come from your iptv provider.
