Xstream or stalker?
A bit confused. We have a provider that we get tv, movies & vod - tv shows. The first seasons are in English but some of the other are in different languages. When I asked, I was told it’s a problem with xstream accounts and I should subscribe to a stalker feed. Is this true?
Thinking he is crapping you mate the issue is with the provider supping wrong feed nothing to do with Stalker or extreme codes API just like you want to tune into a program and when you select the channel you get something else not even close to what EPG says that is Server issue a mismatched recording file ..
So, there some good stalker supported services out there. But for your specific issue there is no relation.
