I purchased the following box for the DVR. I am getting judder when watching live TV, IPTV. I have tried every resolution and frame rate. Nothing helps yet recordings playback perfect no judder as well as other streaming apps, Disney etc.
Unfortunately, I do not see any options to try a different player.
Any suggestions are appreciated.
I am open to suggestions for a DVR solution that works. I have tried using TVMATE but the recordings are hit or miss. I wish there was a box, something hardware-based that was reliable.
I forgot to mention I am running an ethernet connection with over 100mps.
Appreciate any help, thx
Hi @aeg
So is it only streaming live tv through your provider or does it also do it on others Netflix, etc?
I would strongly suggest reaching out to BuzzTV. Mine works perfectly. They may be able to help you or replace the device. Also, you may want to try increasing buffer size in settings.
My provider works judder-free on fire tv and fire cube. The judder is isolated to the BUZZTV box. All other apps, Netflix, Disney, HBO Max judder free. Thx
I am glad to hear the live tv works without judder, I like everything about the box, if I can just get this resolved I would be a happy camper. I will look into increasing the buffer size. If no luck I will reach out to BUZZ TV. Thank you.
Found the buffer settings as well as a choice of two players. I changed to the standard player and increased the buffer size. This seems to have solved my issues. Thank you, TP.
Awesome to hear!! BTW, thanks for being a Patron!
This topic was automatically closed 2 days after the last reply. New replies are no longer allowed.
Well well…i was digging around in the backroom of the man cave today and came across this beauty..totally forgot i bought one
Buzztv XRS4900
BuzzTV XRS 4900 Review - Great Android TV Box for IPTV (2022)
4GB Ram 128GB Rom and have no idea why i stopped using it as it looks brand new…gonna stick an ssd HD in it and give it a run, boots up just fine and i’m playing with the diff home screens right now…far as i can tell you can’t even buy one now..oop’s remember now as i was pissed they wouldn’t help with the buzz tv5 box i bought so i stuck both of them on the shelf in my man cave…i’m a happy camper and will be testing this thing all week
Damn!! playing 4k video like no business and pix is great with no buffering at all
Sys picker worked great with a bluetooth mouse and keyboard and i made a tivimate folder on the HD and it recorded the laker game with no prob..nice find…i got to look at what other stuff i got back there from yrs ago..every box that troy has recommended in the last 3yrs i bought one
my X96 max still works good for recording
