Xenon build updating
When updating xenon build on Kodi is there a way to keep the add-ons configurations IE.subs,real debrid,trakt
Are you referring to the Diggz Xenon build? If so, yes to some.
You can set up to save favorites, debrid and Trakt logins when updating. Although you may have resynch the addons you wont need to reauthorize.
I believe its under the Chef Wizard settings option.
Thanks
