Help…I’ve just installed the Xenon diggz build and I can’t do anything with it. It may just be still installing add ons etc. But it’s not the easiest interface.
I hear that titanium kodi build is easier to use, anyone had any experience with this? Also how do you delete a guild to install another?
For a while when Xenon was down I loaded Index of /repo/ and installed the Simplicity build on a new Firestick. I don’t think it takes as much resources and frankly not as good as Xenon but it does seem to have all the stuff you need. You might give that a try.
