#XCIPTV....VPN for XCIPTV
hi…can I use a VPN like Cyberghost on the XCIPTV app?
Sup Ace…
Shouldnt be a problm, XC is just anothr player, the content wld be IP locked, not the plyr
hth…
You can use any vpn with any player, doesnt make a difference.
what di I wrong…the player doesn’t work with VPN
Just a question re vciptv. I’ve loaded my info but it just keeps searching. It looks like it’s almost ready to open but never quite makes it. I’ve tried 3 different apps, but no luck.
Happen to anyone else?
