I have an x96s tv stick that I want to update to android 9. Can anyone tell me where I can the update and can it be updated using my sd card
I have one of these running on version 8.1. Based on what I see, there isn’t much difference in performance or app access vs. android 9.0. I think in order to upgrade to android 9 you would need to enable developer mode on the device and run your upgrade via usb through a PC. This has inherent risks since if something gets screwed up you can brick your device.
@sim_bill thanks for the information. I think I will just leave it like it is then.
