Wolf Launcher - Configuration Help
I’ve configured Wolf Launcher but I’m having a problem with one application, Prime Video. Wolf Launcher is displaying two instances of Prime Video. One of the instances will work and will launch PV, the other does nothing, it’s a ghost. If I use the “Hidden Apps” feature to hide PV, the woking PV app is hidden but the ghost/non-working, PV is still displayed. I’ve resorted to moving the ghost PV into a “Tools” section I created using Wolf Launcher (see attached image)
… any ideas on what’s going on and how to fix this?? Thanks in advance for any help.
You could try rebooting device :wink: If that doesn’t work try highlighting the fake one and see if pushing options lets you uninstall it and if that doesn’t work you could uninstall and reinstall.
It’s fixed but in a weird way …… I highlighted the ghost icon and selected > options, then >configure, and then selected and changed the “Display mode” from “App Banner” to “Horizontal”. This is where is got weird … The ghost app re-name Prime Video and it changed to “Fire TV Player”!!! Go figure …… I then used the “Hidden apps” to remove it from being displayed.
