Have a nice Kodi installation with the add-ons (TV, etc) I normally use. Would like to add a second Kodi app just for a sports build. This is on a Win laptop … but I understand using BlueStacks Emulator Android apps are OK. But if I download a Troypoint fork, will I then be able to insert the build Troy recommended a few months ago for sports? Thought it better to ask before trashing what I already have.
I cannot answer directly for a Windows machine, but on Android devices the TP fork does not replace the Kodi that is presently installed.
So you can install whatever builds or add-ons on the fork that you wish and it is independent of the original Kodi
Oh, shoot, that’s right! Thanks! A build is installed as if it was just another addon, so it only affects the fork you add it to.
Thanks!
That’s the beauty of KODI Forks. Lets you test out other Builds/addonswith no effect on the native KODI build/addons you already have
