I like FEN. Will the Crew Wizard work on different Kodi addons?
It sure will.(Post must be at least 20 characters)
I use the crew wizard on numerous kodi’s and I also set it to clear cache, thumbs and packages on every startup.
Go to Device Preferences-Display & Sound-Advanced Display Settings-
- Make sure match content colour space is disabled.
2.Custom Display Mode-Filter by colour space & select - YUV 422 12-bit Rec.709 - Then go to Display Modes & select 3840x2160 YUV 422 12-bit Rec. 709
Dont need a VPN with RD
You do what you think is right then. Nobody is going to change my mind that it is the right thing for me.
