Since using Streamio (only), the Fire TV screen has a white/gray overcast when playing both movies and series. The info screens (search, library, etc.) are clear and vibrant. I have attempted a couple of “system” fixes. It did clear the 1st time, and that is it. Any suggestions? Thanks.
What Fire TV device are you using? Could also be an issue with the TV it’s connected to. Are you having these resolutions issues with other apps or devices?
It is an Insignia Fire Tv. And it only happens on Stremio.
Does this happen with both the exoplayer and libvlc player? Have you tried using an external player besides those two? Just Player and MX Player are two popular ones to download and try. Not sure if those are in the Amazon app store, but try switching different players.
Just Player and MX Player are available in the Troypoint Tool Box.
Thanks. Player makes no difference in whitewashed appearance.
