When Will a New NVIDIA SHIELD Device Be Released?
That’s the one I can get on Amazon Canada for $250 while Formuler Canada is $285. Guess I got a decision to make, spend my tax refund on cremation or a new Streaming device. Any takers on which one wins?
all my older boxes with android 9 or 10 work great with tivimate and i have several that i haven’t even opened…my newer t95z doesn’t work with tivimate to record…but my older ones with android 9 do?
i record alot of fishing and hunting shows as well as the soaps my GF likes.
sparkle iptv player can work on the newer ones to record
i’m going to wait awhile to see what the new buzz tv box can do
and tivimate needs an update to work with the newer android OS…seems the dev got fat and happy and no longer updates it?
Works on the shield. Should work on the T95Z as well following the instructions. With X-plore you should be able to grant permissions to access /data and /obb. Wish I had a T95Z to do it and give the steps to everyone. There are lots of articles on doing it even up to droid 14, even ones for the Firesticks.
but isn’t the shield only on android 9? maybe that’s why it works on my shield but my t95 is on android 12 hence doesn’t work
Nope. Up to 11. But I have a device on 14 working just fine.
I have 2 T95Z’s 6+ years old running Android 7. Rarely record anything but no problems in Tivimate when I’ve had to
Well Google has now joined the ranks of Amazon. New update has now disabled the ability to uninstall updates to the files app. So now that makes things even harder. So waiting for the real brainiacs out there to figure this out, AGAIN. :face_with_spiral_eyes:
I always install files by google as a backup to xplore. :+1:
not sure but there was a time that files was hard to find or install but when I could get it it solved lotsa issues. Recently tho ive been using stock android and have no issues.
bought the z11 pro max about 6 months ago… takes a little getting used to but really like it!
Troy states in his review that you can’t use record to external and have to use the internal storage.
I think it has something to do with the MOL3 not allowing. He also installed Tivimate on the device and I think he said you could record to external using Tivimate. I wonder if Sparkle would work on the device?
Have you tried doing any recordings and is there a workaround to get recording to an external using MOL3.
Not a big deal, but on those rare occasions it would be nice to have a workaround in place.
I’ve never tried mol3 and that is the big question. For now I’m in a watch and wait mode because I cant get a definite answer to questions. I always record to local (lan) storage.
This MOL3 is being talked about by many, as the new king of the hill toppling Tivimate from its pedestal. Dunno, but just as Nvidia has stopped doing any updates of late, as Tivimate is not either.
Meaning both will be replaced eventually by more hungry developers and manufacturers.
MOL3 gif
Hello @Powerfader hopefully I didn’t misspeak somewhere on this. It is the opposite for Formuler. You can only record to external, not internal on Formuler devices. Seems like their recording is top notch and works EXTREMELY well in my testing. Probably best recording I’ve seen in any IPTV app.
Ok, thanks. I probably got the info backwards. Anyway, I will be getting the Formuler Z11 Pro Max BT1 at the end of this month. I’m excited to try out the MOL3 player.
Found this little tidbit of info, ā€œtime shift doesn’t work without externalā€.
I think I read somewhere recently Nvidia is the first TRILLION dollar corp. Basically, because of AI
Powerfader let us know how the recording works and what you recorded to, USB stick Nas Etc…
A new Shield should have more internal storage and full access to the Google Playstore.
