What's Working with Real-Debrid
EZ Maintenance address worked but you have to leave off the s from https . Thanks !
Well, RealDebrid is working on everything I use (apps, Kodi), so I’ve cancelled my subscriptions to AllDebrid and Torbox.
Fingers crossed!
You are not alone. RD doesn’t work for me either in Syncler. I also have Stremio and it still works fine. I now actually find Stremio has more plusses than Syncler, so I’ve made it my primary for the last 1-2 years.
You may want to try free Stremio. I don’t see any major advantage using Syncler, even though I still pay for it. :upside_down_face:
Umbrella works awesome with Premiumize also!
give kodi a try. I was in your shoes a few years ago using cinema … and intimidated by kodi. decided to dive in using troy’s guidance and so glad I did. The streams using addons in kodi are so much better.
Kodi likes to eat with reckless abandon, however, and can get quite fat if you don’t stay on top of maintenance.
…that’s part of the extra work you have to put into it.
There’s programs that can automate that help however.
Spoke too soon! This morning BeeTV, FilmPlus, Stremio (torrentio) and Kodi (Crew) are working with Real Debrid but Cinema (3.4.1) has stopped (it worked fine up until last night).
EDIT: Just checked reddit for sh_ts and giggles and found the solution to Cinema’s issue:
“go into settings/account then scroll to the bottom and turn off the “turn off resolve premium links” switch”
Cinema is playing links in RD great again!
If susbscribed to both, can both Real Debrid and Premiumize both be linked and used at the same time on Cinema? With Both having links show up?
Not sure on Cinema as I don’t use but Yes on KODI. RD links in Red, Premiumize links in Blue on Umbrella KODI Addon
I have noticed on all apps that the number of working RealDebrid link is now far fewer than previously (2 weeks ago). I’m seeing single digit numbers now vs double (and sometimes triple) digit numbers of links previously.
Maybe something to do with their efforts to avoid observation by those who shall not be named?
Tried adding Prem and RD together on Cinema HD but it didn’t work for me .
Make sure to turn off “resolve premium links” in Cinema settings.
I did this it appeared like more links played. Thanks for sharing the workaround.
Same here. I just stream . Downloading is a no no and you can get in trouble for it.
As per Real Debrids X account it looks like they are being forced to block copywritten material to comply with anti-piracy. It’s not a matter of if, but when . I myself will wait this out and figure out what my best alternative will be.
Well seems like the KODI Addon Dev’s have a work around for now. If RD does whatever it does to block streams BUT the Dev’s figure out a work around (for now they have) then RD won’t do anything more. They have their A$$'s covered
That is until the French authorities tell RD to do more.
I’m done with RD after seeing their remarks to customers.
Maybe but don’t think it will happen. They are doing their part and if a 3rd party finds a workaround it’s not RD’s problem. Are they going to tell RD to shut down the KODI Dev’s? No
Let’s hope that you are correct.
But as long as copyrighted content can be accessed through their service, RD is going to potentially be compelled to take measures that will limit uploading such content to their servers.
