What's Working with Real-Debrid
I signed up with AllDebrid on Monday. They cancelled my account Tuesday. I got the refund on my Credit Card today (Wednesday).
Update:
11/27 at 12:30pm CST.
The Crew is now fixed, I was able to reauthorize my RD and have a ton of links for movies and TV
Umbrella, Fen Lite, and Cinema HD all working with RD, lots of links. It might be my imagination, but it seems like there are more links than before in RD
Are you using Kodi, Cinema, Syncler??? with RD?
My RD is good until June 2025. It is not working on Syncler or Cinema.
I read on Redit that RD was working again.
I am surprised at people asking for refunds. It is so cheap and the use I have had with RD over the years has been fantastic for such a cheap price.
Any help appreciated. I have xenon plus build on kodi with RD. When I open umbrella and a couple of more apps the movies are there as are the downloads for them… The problem is the downloads are uncached and I cannot open them.Is there a way to cache them. I was told to download cocoscraper but it would not allow me. Any suggestions appreciated.
If you are using Xenon Plus build you dont need to do anything. Cocoscrappers is already installed and set up.
After this recent change they are called unchecked.
I left RD and went to Premiumize so not sure how it looks now.
Edit: i tgink the work around involved not using cached files. That might be what got rd ro change.
Check to make sure you are using the updated umbrella version (6.7.27)to go with the new RD setup.
If you are new to xenon build.and arent sure if you.set it up properly let us know. Some people can help you.
It did have coco build but still could not open up downloaded movies. Just switched to Aspire Build and all good. Thanks
Ah! I authorized Premiumize on my Cube and left RD still active. Then did a search for a movie and RD links popped up as well as the Prem.Me links. I did notice that all of the RD links said “unchecked” and wonder what that meant. So JPM69, your edit answered that question for me. Thx!
RD is working fine for me…no issues “yet”.
-RD works fine
-Using NordVPN
-Live in CA, VPN out of LA
-KODI/DIGGS/UMBRELLA
-IMPro
-I use CINEMA also with no issues
Most RD links working in Cinema in Arizona
The thing I don’t understand is how these RD files are working so well if they’re uncached? I got a 120GB version of Apocalypse Now to work yesterday with no buffering. That couldn’t have been a live torrent.
Yeah i dont know the tech side of it. But they are calling it "unchecked " not “uncached”, right?
My guess this work around lets RD still work but not get in trouble. At least for now.
You got it @JPM69 . It’s all in the words. Cached v uncached and checked v unchecked. Much easier to change one word in a cache of code than entire lines.
Most of my RD links in Cinema HD apk are not working. Every now and then a link will play. My vpn is set to chicago. Will changing location make a difference?
RD should just remove the links that won’t play. Instead, of giving me an error message. My subscription doesn’t expire until 30 Jun 25
I don’t think the links not playing is RDs fault, I suspect it’s the Cinema HD app.
Dang, I wish Cinema hd would fix that. The updated version didn’t work, so I deleted it. I’m missing my 2024 hallmark christmas movies. Stremio doesn’t have most of the christmas movies.
I’m in New York on Long Island, Express VPN, NO links at all on CinemaHD which was perfect, and Cyberflix, which was great for TV only, has absolutely nothing. I’m fortunate to have an IPTV that has everything I want, so I’ll ride it out.
I did add a service called Onstream months ago which has a ton of content, nothing to do except find it and press start. Here’s Troy’s link:
KODI might have the movies you are looking for? And there’s plenty of RD links
I’m not a Kodi user. It intimidates me. I might need to build up my courage and give it a try over the holiday season.
RD is working ok with my Cinema HD. No problems at all. Also have surfshark set for UK use
Whats PM?
