What's Working with Real-Debrid
I started a new stremio account Miki, all sorted now.
Well at least you’re flexible. Most would just panic. :joy: Have a great day @Anth
Should be XMovies. Everything working fine for me.
Only one or two links in Cinema HD working for me. I’m find as long as one plays.
Found out what the issue was, i had changed video size limit to 10 and nothing was coming through.
Changed it back to no limit and everything is working for rd.
This was the same for torbox just leave video size limit to default, no limit.
Rd is down at the min but torbox bringing in some nice links on torrentio.
RD/RD+ links working for me in Stremio (Torrentio 0.0.14) and Cinema 4.0.1 but zero luck with BeeTV or FilmPlus.
Found this on Discord, thought it might be helpful.
Updated **
******** REAL DEBRID ********
The following addons are now working with RD, i will test a few more later in the day
. Umbrella
. Fen Lite
. The Crew
** . Halcyon
** . THX1138** ( links show as uncached Torrent - If you click the link it will still work )
** . Alvin** ( links show as uncached Torrent - If you click the link it will still work )
. Sealteam 6 ( links show as uncached Torrent - If you click the link it will still work )
** . Absolution** ( links show as uncached Torrent - If you click the link it will still work )
. Homelander ( links show as uncached Torrent - If you click the link it will still work )
** . Shazam** ( links show as uncached Torrent - If you click the link it will still work )
** . Moira** ( links show as uncached Torrent - If you click the link it will still work )
** . Chain Reaction**
** . Quicksilver** ( links show as uncached Torrent - If you click the link it will still work )
. Taz 19 ( Fen Fork ) - For this to work, please uninstall Taz19 ( if you have it installed already, exit kodi by clicking the power icon, then install from zip file again, install the addon, then ENABLE EXTERNAL SCRAPERS and INSTALL COCOSCRAPERS and authourise RD with Taz19 addon. Url for Taz19 addon is Index of /octopus
. Buds ( Fen Fork ) - For this to work, please uninstall Buds ( if you have it installed already, exit kodi by clicking the power icon, then install from zip file again, install the addon, then ENABLE EXTERNAL SCRAPERS and INSTALL COCOSCRAPERS and authourise RD within Buds addon. Url for Buds addon is
Index of /repo
The Crew is not working for me as of 12pm CST 11/26.
When I try to re(authorize) Real debrid I get the “ResolveURL error” check log notice.
RD working in Umbrella, Fen Lite, and Cinema HD.
I uninstalled the Crew and re-installed, but still no success.
I just bought 6 months of RD and when I went to use it on Cinema HD it won’t work. So I changed to the new stable version of Cinema 3 ad free and it won’t open. Help!!!
I downloaded that version as well and it wouldn’t open. So, I deleted it.
How do you update these addons on the xenon plus build for kodi. thanks
I don’t use xenon so know nothing about but I’m sure someone will chime in that knows about it :smirk:
For Xenon Plus:
They usually update when you start up kodi but you can also go to Addons menu and select it. If there are updates available there would be an option called “available updates”. Click that and you can make a choice.
If there are no updates for any addon that option won’t be there. But the “Recently Updated” option will show you what was Recently Updated.
Normally if you let the build update the addons for a few minutes at startup you are good to go.
If you want to check a certain addon. You.would long press it and select Information. Then versions to see if you have the latest.
I’m only getting a couple of links in cinema hd aslo, and no 4k links. Mostly 720 and 1080.
What version of Cinemahd are you using? Did you do something to get RD working again?
I’m using version 2.0.6 of Crew. I uninstalled and re-installed theCrew. when kodi starts, I get the message ist back relax message. then is scrolls updated free providers, updated paid providers etc.
But when I go to “tools” ResolveURL, and try to reauthorize Real debrid I get the message ResolveURL error check the log for more information.
Clicking on reset my authorization, I get the message “ResolveURL Real-Debrid authorization reset” But it really isn’t. I try to reauthorize and it just gives me the same error message.
So I have no RD in The Crew, but RD working fine in Umbrella and Fen Lite. Also only getting very few links in Cinema HD and no 4k links, maybe 2 1080 and a bunch of 720’s
Update to not being able to authorize Real Debrid in the Crew. I tried authorizing some other services (premiumize, all debrid) I was able to start the process of authorizing them. So The Crew is not letting me authorize Real Debrid, but they are allowing other similar services to be authorized.
Umbrella, and Fen Lite are working very well (Umbrella is smoking fast!), so the Crew is not a big issue. To me it is the weakest compared to Umbrella and Fen Lite
Updated Umbrella add on and RD is working great for me.
RD is still working up in the north with vpn and of course Fen which I have used for years.
I just renewed for 6 months and it works just fine for me. Those seeking refunds, RD is giving but will ban you for life, No questions asked. So better to eat the money owed for now
