What is the equivalent setting on ONNpro in Developer Options for Enable Unknown Apps on Firestick, etc ?
I don’t think it’s under Developer options. It should be under something like Settings/Apps/Security & Restrictions/unknown sources/Install unknown apps and enable the apps of your choosing.
Settings > System > Developers Options - then enable Developers Options
Yes. Under Apps and then Security there is an option to turn off Scan app with Play Protect and also Improve harmful app detection.
They are both off on my device. I believe the play protect option is the same as the playstore option.
I think he’s looking for the setting to enable the install of 3rd party apps, or install from unknown sources.
Troy has covered this.
I’ll just say for the record you arent jailbreaking. Troy recognizes that as well in the article.
Even though it’s not the Pro version I believe thr same holds true for instructions.
