What Are IPTV Connections?
Tivimate is just a player has nothing to do with any buffering. Buffering is typically an issue with your provider
I’m aware. I meant PIA. I clarified what I meant. I appreciate the response
do a quick check by turning off the vpn if you are using one. Also pia has most likely more than one instance of that channel. Turning the buffer up on tivimate can help as well.
I’ll increase the buffer size and see if that helps. I feel like if I turn of the VPN after it freezes, I know it’ll be fine just from the fact that when I switch to another channel and back quickly, it resolves itself. What’s more of a concern is I’ve never gotten response when I’ve asked a question. Love the info on their site and easy it is to make changes on the fly. Just want to what I’m missing. I send a message from the website, receive a message that says I’ll get a response soon and weeks go by.
Without going down the search hole, do you have a quick reference on how to multiview? I want to do the same thing for the Olympics as well.
In Tivimate From the channel you are watching long press the ā€œenterā€ button on remote. Choose Multiview from menu. Then add additional channels you want. Some other options too so just play around with it to get what you want
Many IPTV services sold via website accounts work this way - you raise support tickets, get auto message and wait for a reply.
Re buffering
Basic steps to try fix local issues,
I agree in how these services work alot of the time. Just saying it would be nice to get a response. Be more willing to recommend them if they did. Nevertheless, I appreciate the link… I’ll see if this will benefit me.
Thanks
