What Are IPTV Connections?
Did you use their method to pay with bitcoin?
nope I used a card
I pay with Bitcoin using Coinbase. Also, I always purchase two months at a time. Coinbase requires a minimum amount for transfer. Never had any problem.
I have the 8k also and she has asked me to let her know if I would like to purchase more connections.
My understanding is per app - as others have stated one connection and can view multi-screen with Tivimate.
Not tested using 2 apps on one device to connect to a one connection service but I know you can’t use 2 devices at the same time to connect to same service - you are free to set up on as many devices you want but only one can connect at any time.
Multiple connection service or multiple services
PIA offers 8 connections for $40 per month = $5 per connection or $60 per year - Amberbaby service options the most expensive costs $35 per year
I would go for multiple services - if one goes down you have a backup.
I might have to look into PIA after the first of the year, i’m set for now with 2 services but it never hurts to know where to head to next….
Any reason in particular that makes PIA look attractive? There are so many choices, just curious why you like this one,
@GraceWilson ….it is one of the few i have seen that actually has a channel listing that you can view, and there are a ton of channels, including lots of 24/7’s, if that’s your thing, and if i understand it right, YOU pick the channels YOU want, not sure if that’s the same as saying ā€˜just give me USA/CA/UK or not, or how actually picky you can be, but sounds interesting enough to try for a month….
Keep us posted. Your wisdom here is a shining beacon. Merry Christmas.
I think you may have me confused with someone else cuz, if I am the voice of reason :face_with_spiral_eyes: around here, then we are ALL in trouble, and someone else needs to SPEAK UP quick !!!
But seriously @GraceWilson , thank you for the kind words and Merry Christmas to you and your as well….
It is true ala carte….Countrys are all grouped. catagorys such as sports are grouped etc….it really is the only one ive seen like this where you can for instance pick 2 Canada channels and say 5 UK channels and 10 sports channels any or all and it gives you an m3u and epg file…
Hey @TXRon , thanx for the reply, that’s Xactly what i was wondering….1 from column A, 17 from column B etc. etc. etc…. And how does that work….you do the picking yourself as part of the sign up and payment process, or talk/text/email someone?? either way I gotta admit that is pretty dang cool, and nothing i’ve heard of before !!
once you sign up/pay which is pretty fast then on your login page that shows your subscription etc the options are all there where you can pick what you want….
edit…..just above this screenshot on the dashboard it list urls/login info
Private IPTV Access : Reliable & Best IPTV subscription service provider
NICE….Thanks @TXRon seems simple enough even i can prob do it without messing up….2 more ?’s that just popped up….#1) at a later time can you make changes or is a one shot deal….and #2) can we use a player of our choice….thanks again, always great info….
yes you can change as much as you like. They dont have their own player that I know of…but I have tried the urls and epg in sparkle and emby.
forgot to mention they do have xtream codes as well as a web player if needed.
That is pretty slick, i asked about the players cuz it shows Smarters Pro in their description of the different subscription levels….i lhave smarters pro, and sparkle plus as well, like them both….i remember a while back when i was new to TroyPoint and i posted a question about smarters and your reply was ā€œThe best solution for Smarters is TiviMateā€ā€¦.and i was like, now that’s a straight shootin’ answer rite there….i like this guy :rofl:
Also, from your dashboard you can select individual Movies and Series, or the entire category, the same way as Live TV.
I’ve found the EPG URL is excellent and populates most live TV listings.
also very cool….thank you for that heads up….
