Greetings - I used to occasionally use ExoduxRedux on a Win10 machine running Kodi Leia. However these days it has no where near the content it used to.
What Addon can I install on a Win11 machine that will behave similar to ExoduxRedux on Leia ? I especially liked the download option. Do any current Kodi add ons have this feature that will run on/in Windows 11?
I did try to install the Leia build on Win11 but you get to a point where it will not go past.
Wow Exodus! Blast from the past. Long time KODI user here. Yeah the Addons work on Win 11. I mostly watch on ONN Pro but when I need to download I do on my Win PC. You can download from any Addon. I rarely download from KODI but when I’m going to be in a plane I do. KODI 21 Omega is the current version and what you should use. You can get it from the TP Toolbox or the KODI site. And there’s a ton of working Addons for 21. The 3 I use the most are Umbrella, Homelander, and The Crew. Do a search here or on Google and you should be good. You will also need a Real Debrid account as well. Free sources are few and far between
I have Windows 11, and use version 21 with Asgard, Halcyon and Scrubsv2, these all work perfect.
stremio works well to
