Weyd settings? HOW TO? Instruction Manual
Hi, thank for the message. No all is good now, I think it just took a while to correct itself. TBH I just use Weyd as a backup, Syncler is my go to. Doesn’t hurt to see what the competition has to offer :grinning_face:
Trying to sign up but I never get a confirmation email sent to me. Any ideas why?
Hi, have you logged into your account to see if it is active. Check your spam! Hope this helps.
trying to signup on my computer so I’ll try signing up on the installed app. Thanks
Have it all installed but there is a way to get a trial?
Can I try before I buy?
weyd does offer a 7 day trial to every member! To request a trial please proceed to https://weyd.app/subscriptions/new and click, “Request a Trial”
Got the free trial. All setup with my RD and Trakt. Nothing plays because debrid returns an error. So wonder what’s so great about this. Something I.m not setting up correctly? Thanks
Go into settings then Scrapers and put this in there bit.ly/weydz then Refresh scrapers and it should work
This is different than the tinyurl one, better? Also no links ever show up
RD does not work that good with weyd because of the problem they had so I use https://www.premiumize.me plays better tinyurl is a old link this is the updated one
Also go into Settings >Accounts >Real-Debrid and make sure “Ignore Cache Status” is turned on.
I use RD with stremio not weyd
That worked. Thanks
For the people that use weyd, go into settings and refresh your scraper. There’s been an update
REFRESHED the scraper and nothing. bit.ly better than the tinyurl?
Good morning this is what they posted. Why you have to change it. I do notice if you use RD not every link will play with weyd , now premiumiz it plays better. If you only use Rd and want better results use stremio Here
It is working much better now. Not sure if it needed some time. Noticed it pulls up much more feeds from many sources
Payment choices are bad for many. CC is a no no and crypto? Not doing that. Too bad I would have liked to try it for a year
I have been with Weyd since the beginning and used my credit card. Never had a problem, I have a credit card that has a very low limit and that’s what I use for online shopping and paying for stuff like this
