Walmart ONN / Trouble with External Drive and Digital Keyboard
Thanks for all the info.
What I’m getting here is the only way to solve my issues is to uninstall everything that went into the Wolf Launcher installation (Launcher Manager, Sideload Launcher, Wolf Launcher, Jio Sphere and Fast Track Killer) and then start from scratch following the video again.
I’m assuming, now that external storage is working on that device, all the re-installed apps will go to the external drive.
Are there any of the Wolf Launcher apps that should not be located on the external drive and if there are, considering my past experience, will I be able to move them back to internal storage without any problems?
leahcimj
Gave up doing local USB storage on any devices. Too many random disconnects that can not be stopped.
I would assume apps can go back to internal always have been but ONN box is different. Honestly should get a expensive device for all this you’re trying but I never have needed extra storage on ONN boxes for all my apps and I have a lot of apps and still fit but TDUK app killer and TDUK cache cleaner is the reason for that it really erased any unnecessary things that take up storage I even have KODI on ONN box and stick still didn’t need extra storage.
I can’t get the iPazzPort keyboard through the OTG cable to work either with the onn 4k google tv box. Have you had any luck? Thanks.
Hello Cousinbrucie 1
Got the iPazzport to confirm that it was synced but if would not function (type).
Got it to accept external storage but I could never get it to accept an ethernet connection. Only runs on Wifi.
I guess that’s what you get for $20.00 but on the other hand, considering what works, you’re getting alot for $20.00
Regards
leahcimj
If you use the microphone at the top of the keyboard you can speak what you want to enter. That’s always worked great for me. Never used an external keyboard. Good luck
Hey, Pete. At leahcimj’s suggestion, I turned off ADB debugging, power-cycled the onn box, and now I can type with the iPazzPort keyboard.
That’s great news. Glad you got it working again :+1:
