I tried to install Superman build.
Typed in Index of /repo/.
Named it cman.
When I click on ok after naming it. Nothing happens. Says it can’t find the address.
Internet connection is working.
I am also using a vpn.
Sorry. Trying to load the build on the Walmart google onn.
Any help would be appreciated.
Thank you.
Make sure your spelling is exact. You also might try turning your VPN off
Thanks Throttlejockey.
I had to turn off the vpn to load it.
Then the content wouldn’t play. Kept saying no stream available. Turned out my real debrid account expired. Had to renew. Lol.
All is well. Thanks again
Anything I have loaded like this has always worked with VPN on. Wonder why it made the installation go from not working to working…im confused. Not sure i would install anything if that was the requirement lol. I installed Superman build a couple times, both with VPN on.
Yes that would make one wonder? Everything is getting more sensitive to vpn’s
