I’ve just purchased the google tv streamer, uploaded everything I need so far. The one issue I am having though, is vpnsafetydot is coming up as not suitable for this device.
Does anybody know a work around.
Try either one. Monitor dot or safety dot.
If the new google tv streamer is running android 14, then it blocks apps designed for android 6 or lower.
At the bottom of my webpage (www.MonitorDot.com) it has instructions on how to bypass this restriction, but it is somewhat technical to do.
This hack works with my Monitor Dot app, but it might also work with VPNSafetyDot if you like that app better.
(edit: fixed typo in link)
