VPN Not Staying Connected with IPTV Merge
I recently notice that if I activated IPTV Merge I had problems with my VPN staying connected. I eliminated the problem by turning turning IPTV Merge off. Has anyone had the same type of problem?
If you do a search and read the posts you will see that IPTV Merge has been a problem for a lot of Kodi users as it seems to overload the channels and Kodi.
Search Is Your Friend...!
