VPN Monitor Dot On
I recently switch from my Firestick 4K Max to the newly released ONN Streaming box… BTW, very happy about switching!! The issue is I was going to download the VPN Monitor Dot from Troypoint tool box but received a warning prior to install that its not the latest version for android system and could jeopardize my privacy. So, I deleted the install… I used the same VPN Monitor Dot on my Firestick 4k Max and never received any warning prior to install…
Anyone know of a solution for this ? Thanks
Did you go through and disable play protect like Troy’s video shows?
Anything from Troy’s Toolbox is safe to install, btw.
I disabled play protect and that solved the issue… Thank you !
