VirtualHere allows USB devices to
I found this useful(for the techies…and maybe a few others :eyes: :sweat_smile:
I discovered it in the play store and the investigation began. :sunglasses:
VirtualHere allows USB devices to be used remotely over a network just as if they were locally connected!
Traditionally USB devices needed to be plugged directly into your computer to be used. With VirtualHere this is no longer required, the network itself becomes the cable transmitting USB signals (also known as USB over IP, USB/IP, USB over WiFi, USB over Ethernet, USB Device Server).
> This USB server solution is perfect for allowing USB devices to be used remotely over a LAN network, over the Internet, or in the Cloud without the USB device needing to be physically attached to remote client machine. The USB device appears as if it was directly attached even though it is plugged in to a remote server, therefore all existing drivers and software work, no special changes required.
Home | VirtualHere
https://www.virtualhere.com/
