I followed instructions to install advanced AP K on my new galaxy phone. Uninstall youtube updates. Went to chrome and allow permissions. Went to Troypoint toolbox and downloaded in the correct order micro. G, youtube and vanced. On a couple of the steps, my phone does not give me the options that the video shows. I tried for an hour over and over again to get vanced installed on my phone to no avail. Any help or suggestions would be welcome! Thanks all!
Hello, this process is not very easy and more than likely we will be removing those files from the Toolbox. We suggest using Newpipe instead. Much easier.
Thank you very much. I will give it a shot!
Sincerely,
Hal
Wow that was very simple installing New pipe on my galaxy s24+ phone. Thanks a million!
Or there is yt revanced on lite apps. I’ve downloaded on 3 different devices including my s23u and had no problems. You have to download microG first which you’ll find on the same site.
