Using Trakt-Is this a useful utility?
Should I be using Trakt for my Kodi streaming. Not quite sure of the features and benefits that it will provide to me. Looking forward to hearing the opinions from this group. I have not seen much posted on Troypoint.com about this. Thanks in advance.
Just have to use the search. Trakt has been extensively discussed.
Trakt is Fricking Awesome! I highly recommend it with KODI been using it for several years. This is how I add ALL of my Movies and Shows. It’s cloud based so will sync across all your devices.
Sign up for the Free account and Authorize it in KODI (Similar to Real Debrid). Then when you hear about a show or Movie that you think you might like simply add it to your Collection in Trakt. Next time you go into KODI it will be in your “My TV Shows” or “My Movies” (May differ based on KODI Addon) in KODI. also it will keep Track of where you are in any TV series
Exactly what MarkxG said, I use Stremio and Trakt. I would highly recommend you try it.
Thanks-just acquired it.
I’ve been using Trakt for over 5 years now, and the best thing I find about Trakt is that it even works across different apps, such as Cinema HD and Tea TV.
I created folders for each day of the week. I then add TV shows that I like within the appropriate folder - e.g. a show that airs on Mondays, I enter in the Tuesday folder.
