Using DOWNLOADER Codes without using Downloader
On any Android device or PC using Windows 11: Simply type into the URL of your web browser aftv.news/DOWNLOADER code and your desired app or apk will be displayed.
For example, on Silk Browser (Internet) url type: aftv.news/250931 and you’ll be taken to Troy’s toolbox. … Want Tivimate aftv.news/549628 and Silk Browser will take you to the download
Just a fun thing to know, especially if you have an Android tablet without Downloader app
Thanks for the information. Makes it alot easier and less lost space, instead of downloading the whole installer app
Has any one ever seen where downloader once worked fine, then suddenly any URL typed in the search caused downloader app to just exit with no error or warning?
I have two Shields with now same problem and I have to side load both for non play store updates.
Thanks in advance, reinstall does not help anything, just re-prompts for storage permissions and closes itself on any URL.
If the unit is asking for permissions then go to permissions to see if something needs adjusting. I honestly think that sometimes when we use different utility programs they sometimes change subtle things. By the way, I own 4 of thes nvidia pros and i love them!
