Can anyone tell me in layman’s term how to pair memory stick onto fire stick 4k
Which 4K. Most it’s simply a matter of getting an OTG cable >stands for “on the go” cable and it has a female and male micro usb plugs and a full USB female port. Plug the cable in to the max and the power into the cable and then turn your stick on. Once it’s loaded and on your home screen plug the USB drive into the female USB on the OTG cable and follow the on screen prompts. It should ask you if you want the drive formatted. Now remember not all USB drives are created equal. I always had the best luck with Sandisc.
