USB disconnects from Fire stick
Good day ladies and gents:
I don’t know if this topic has been discussed (most likely) but I’m having an issue with my Fire Tv stick. I tried to connect an 8 gig USB via OTG, formatted and partitioned it fine and I was able to move some apps in it but then the USB started to disconnect and connect, making it to the point that I could not use the app anymore and had to reinstall it again internally. I have a fire stick with OS 6.xxx. If anyone can help with this I would really appreciate it.
If you got expanded storage to work on os6 your way ahead of the game. Normally doesn’t work.
True… :wink: but staying that way and perform is the issue. Wonder if it’s a hardware issue, maybe a different OTG cable? So far I made space now and reinstalled the app (Kodi) back but I can’t help that is disconnecting all the time when I try connecting a USB. :expressionless:
Buy a Max, 1st gen and you can easily expand storage. The others aren’t worth the time.
