How can I install 19.4 over 19.0 without redoing my build?
You can just go through install process and it will update your app. Since you are staying within the same build number (19) you shouldn’t have any problems. Problems usually occur when going form say like 18.9 to 19.4. You can install 19.4 through TP app or input the following into Downloader app - troypoint.com/kodistable. Before updating with a build, I usually change the skin back to Estuary as I’ve had problems in the past with a black screen. Once it’s updated, I switch back to the skin that comes with the build.
Installed 19.4 with tp. Just added another, didn’t update 19
