I keep getting a notification to update to 4.70 but it won’t allow me to do it when I click on update. I have install Automatic updates on in the settings.thanks for any help. I did do a search on the subject, but couldn’t find any answers.
I dont use firesticks but as far as tivimate goes I wouldnt worry about that update too much unless you are having issues and in time the update should sort itself out.
Ok ,thanks for the info
hey Boli…
If u still want to update & got it thru playstore (playstore> clik yor icon> my apps> see updates)
Or Apkpure app will let u update the side loaded versions
If not youll hav to backup tivimate data, then uninstall app& reinstall fresh version of the app from unlinked or dwnloader
but like Tex said not crucial, but evry update can fix stuff u might not see (& get rid of yor prompt)
hth…
Thanks for the info,appreciated
