Unlinked question
Actually two questions
  1. I see in this weeks TroyPoint newsletter
    "The following guide provides a list of the Best Unlinked Codes for Firestick/Fire TV and Android users.
    The best Unlinked codes are "
    Do different codes get different content?
  2. Using the code 12341234, there is such a huge amount of available downloads. Is there a way to search or sort unlinked?
Hi Elusive
I’m no expert but I hope this helps answer your questions.
1.The codes install individual libraries each with a various number of apps/tools, some have a lot of content while others have less but really the volume and variety is vast.
  1. There certainly is, when you open the unlinked app (having installed a library using a code i.e 12341234) and you see 12341234 library or any other library you have installed with codes click on the box with the code and up pops a menu bar with a search tab so if you know what you are looking for (filmplus, cinema etc) you will be taken straight to the app you wish to download saving a lot of time scrolling for the desired app.
3.I’ll answer a third question before it is asked, when you find the app you wish to download and install, click on the icon and a progress bar will appear as the download begins, once the download is complete click on the icon again and you get an option to launch, this will install your app to your firestick or whatever hardware you are using.
I was poking around Unlinked last night and wondered the same thing. Thanks for answering a question I had but did not post yet!
I would like to add one more thing to this discussion. After the install is done you should go back to the app icon in unlinked one more time to click on it again #3, and then click delete. This will delete the apk so you don’t load your stick up with stuff you won’t need again.
Have fun and Stream On.
