Unlinked-Downloads
I download apps from Unlinked but cannot find them on my Firestick 4K Max. Where do they go?2022-02-02T05:00:00Z2022-02-02T05:00:00Z
Hey TR…
U probly only downloaded the file… (common occurrence)
U hv 2 go back into unlinked & clik on the stuff u dwnloaded & launch to install them (its a 2 clik process)
It has to go thru the droid install screen
then u should find them in homescreen or All Apps
hth
Sketch,
I went back into Unlinked but could not find the file(s) I downloaded in order to click and launch them.
Also could not find Droid as it says that app is a hardware monitoring app for discovering your hardware!
The files won’t show up in there but the apk should still be there to download again. Just make sure you follow through and launch them to install.
Yes T…
U hv to clik on the apps u dwnlded b4…
to finish the install process
U clik… it dwnlds… then u clik again it asks u to launch ( it begins to install)
After install, it will ask to delete FILE… u can delete it cuz u dont need the FILE anymore
GL
Sketch,
Thanks for the advice. It worked like a charm. You are a credit to the Insider!
No prob T…
Glad u got it & thanx for the kind words…
