Hi, I need some help please. All of a sudden whenever I to download an app on Unlinked I get the message “Installation failed”. Hope it’s just me being inexperienced, but it did work before! I’m using a Mecool Android box
Thanks in advance!
Let’s see if it’s the store…try code 96960000 & see if they’ll download there.
Thank you. I will try that ![]()
Hi, I tried the store code you suggested, but unfortunately with the same result. “Installation failed”
Any other ideas I can try?
Many thanks ![]()
Id make sure your allow unkown sourses is on.
Hey kap…
Unlinked isnt the only magic potion…
Maybe tell us what yor lookin for & maybe we can give u the direct link for dwnloadr or use apkpure or filesink
Unlinked is finicky sometimes
hth…
Hi…think I’ve got it sorted! I uninstalled Unlinked and reinstalled it…seems to be working for the moment!
Many thanks for your advice😀
Hey @kapete Glad you got it working…I’m sure that would’ve been my next suggestion ![]()
I’ve never had a major problem with Unlinked or that particular store…but, as Sketch was alluding to, I also use Downloader a lot & go right to the app source/site or use APKPure…as I’ve found it to be a pretty reliable source for apps that we use. Options Options Options & well done figuring it all out.
Thank you for you advice/help. I’m going to try AAPKPure!
Again many thanks ![]()
No problm kap, anytime…
Heres a cpl more unlinked stores if u don’t hv them
33627466
DAGOBERTS
firestick
have fun…
Thank you Sketch! I will try out the codes you sent ![]()
Amazing how helpful everyone on Insider is ![]()
