Unlinked code 710AB04D
Wrong person to ping.
I was on it today the superstore wont allow you to download the links are broken.
@anon36991227
I just downloaded an app to my TV Boxe from it. Sorry for my earlier post for the short answer see img :pray:
@Matrix
Yes i know, several several apps won’t download, including alot of the main ones. Look at those broken images.
Some may work, try some more if you wish.
(post deleted by author)
@Miki
Relax, it was a typo, mistakes happen.
@anon36991227
Yes some are indeed broken but I didn’t go trough the hole list.
I think @rjwinkler better to try another code for now ore use this one for further notice. Thanks Dracco.
Didn’t send you anything. Pls check your settings thanks for your post
All good, at its current state i wouldnt recommend it.
Hopefully the original op will comment back on their findings. Lets try not to go off topic.
I agree all the listed PINs do not work. Any ideas?
@ostdoc
Yes follow my steps from my earlier post above how to setup and use this code “12341234” this one works.:+1:
@Matrix
We had this conversation, that library is semi down. Chain link errors to most stuff.
@anon36991227
Correct depends on what you download.
Many links don’t work.
