Unlinked App - there was a problem parsing the package
I downloaded Unlinked, but everything I try to download from it has shown me the message “there was a problem parsing the package”. Why would this happen?
Are you sure you are downloading the exact version needed for your OS? Parser errors, from what little I know, are usually caused by a compatability issue
I’m using a firetvstick, so I’m not sure. I usually don’t have any issues with the things I download from Troy’s suggestions, but I’ll try to check.
i would check out what @Miki suggests first then if same do a google search an download from a different source
