Unlinked APK not working
I downloaded unlinked and added the codes but when library is opened it will not download, Keep getting download failed on different apps like film plus/flixoid/cyberflex etc… Looking for a good movie app that is easy to use. Please help
Hey EDawg…jump on Unlinked…use library code 67664537…download FilmPlus 1.7.5 AF version. I just upgraded my older version & it works fine…BeeTV wouldn’t download/update for me so it may just be certain apps…not sure. GL2U :cowboy_hat_face:
pangaeatech, Thanx for the code, it worked like a charm :boom:
Did you guys know you can also download your apps from Unlinked without having to download and install the Unlinked apk? Just in case somebody wanted to free up a little more space on their Firestick or whatever, use the link below and type in your code. (you don’t have to register or anything)
https://unlinked.link/browse/library
Hey i like that thanks alot
Download the Aurora Store and spoof it so you get all of the Play Store content. The only hitch is you’ll need to use an external mouse to help in navigating around the app, but that really isn’t that big of a deal. I use the Mouse Toggle and it works great.
Downloader code: 53402
Here’s a tutorial to help. The actual instructional part of it starts at the 6:50 mark.
(2) :red_circle:ACCESS ENTIRE PLAY STORE ON ALL DEVICES ! - YouTube
If you are US based is there any way of enabling the Aurora store to have the content of the U.K. play store?
Hmm…? Good question, but I don’t know.
Trying to get film plus 1.6.6 back, un-linked only seems to have 1.7.6, thanks.
