I have a strange thing going on. After downloading cyberflix from unlinked it works great. The next day when I open up my Android box and I go to the homepage I will see CyberLink with the rest of the apks and after a minute it disappears and have to go to unlinked and download it again and it still has all my settings. I have had to do this three times.
Try disabling Google play protect.
I have found the option to disable Google Play services but that also disables the Play store
I am not so sure having the play store disabled is such a bad thing. I disabled play protect over 2 years ago and have not missed or needed to use the play store the entire time.
You can get anything in the play store other ways. Your apps don’t just disappear I believe play protect is doing it
Both of you guys are correct, play protect is flagging cyberflix. Thank you for the info. I’m looking at Sinclair right now might use that instead
