I was going to switch skins on kodi today and received this error message when trying to get more skins. (settingings, interface, skins)
“unable to load skins skin is missing some files” This happend no matter which skin I chose.
Kodi 19.4
Thanks for any suggestions
I don’t know if you solved this issue but it happened to me today. I waited for even for it to download and then got that message. I tried a different one that worked then went back and retried the one that failed and it worked perfectly. Good luck
Thanks, I’ll give that a try. I had pretty much just given up on the changing skins, so this will be interesting if it works!
