Hi Guys, just soliciting your ideas and opinion. I have installed successfully a 32Gb USB flash drive using OTG wire on my Fire stick TV4k Max to expand my storage data. I have successfully downloaded Kodee 19.3 onto my USB drive. However, when I tried to download a Kodi build, It just goes back to the Amazon main screen where the Apps are. I tried many times but in vain. Any help and suggestion would be much appreciated. TIA.
Make sure you have “install from unknown sources” in Kodi settings.
